So...what exactly is Virtu MVP?
26 Aug 2012
Am I right by saying the Virtu MVP software is basically, you're connected to the core graphics but it gets the power from your card? I'm confused :confused:
It's a gimmick, the software is awful and it gives negative performance when on in a majority of games. I've done some extensive personal testing and it's really not worth your time.
could have been great but it's a long way from being what they market it as.
But yes, it is supposed to be a Hybrid graphics solution which allows you to use the iGPU mixed with the dedicated GPU.
I wouldn't say its all bad, i have had a few games where it helps, especially the dynamic v-sync.
You will find it will give you some crazy Heaven Benchmarks aswell.
Butonz is right for the majority of usage though. sadly it just isn't quite up to scratch. Personally i hope development continues and it will become a popular piece of software.
Well it improved my performance in sleeping dogs with the latest CCC beta drivers with no errors or problems.
But as some one said a lot of it is down to personal use some like it some don't.
