SOAP PHP and Arrays
13 Nov 2003
Manchester
Hi All
Got a slight issue with some code I am trying to work out.
I need to use SOAP to retrieve some records and insert them into an array
Below is the code
Code:
<?php
	$client = new SoapClient("******/Service.asmx?wsdl");
	$contact_sources = array($client->GetContactSource(''));
	print_r($contact_sources);
	foreach ($contact_sources as $value) {
	echo $value;
However it doesn't seem to work.
A print_r on the array displays the following.
Code:
Array ( [0] => stdClass Object ( [GetContactSourceResult] => stdClass Object ( [string] => Array ( [0] => Ambient Media [1] => Direct Mail [2] => Magazine Adverts [3] => Spanish Press [4] => Website ) ) ) )
which says to me that I have got something with the query assignment wrong, but I am not too hot on this and am not sure how to fix it.
Any help would be appreciated
Thanks
Aaron
It has returned an object inside an array.
I haven't used any of the SOAP functions but you could get at the inner object with:
PHP:
$contactSources = $contact_sources[0];
* edit * was being dozy.
