Socket 1155 Build
Any cheap 32GB Kits?
1066Mhz would be good, but will the performance difference be noticable?
And all these are compatible?
All these will work ok, 1066mhz kits are similar price to the 1600mhz and in some cases much dearer.
if the Xenon chip does not run the memory at 1600mhz you can run these lower without issue.
At the moment the 32gb specced is probably one the cheaper if not cheapest options.
