- 5 Sep 2013
Hi,
I built a pc last year and recently upgraded to sli.
I've got an matx Asus Gene V but am looking to upgrade to a full atx board because I'm suffering with heat issues with my current set up. I think this is because of the proximity of the 2 msi power edition 670s and the CPU fan meaning that the top GPU fan is working very hard. Temp differential is -85c top gpu and 57c bottom when both under load and I've tried swapping the cards etc.
As such can someone recommend me a replacement motherboard to go with my i5 3570k? If you don't think a switch to a full will help can you let me know as perhaps I should also look at water cooling as an option.
Thanks, Elliot
Thanks, Elliot
