I have a colleagues (again!) PC. It is an Athlon XP 2400+ Socket 462 based system.
Initially it would not power on at all and after various tests I realised a number of capacitors on the board had blown - they were not visible initially.
I have got a new board for him - an MSI KM2M Combo.
Plugged CPU, memory and hard disk in. Seems to be all auto detect so no jumpers to set that I can see.
Now it WILL power up OK and goes through the POST fine but when it starts to load windows the HDD (with XP on) sounds as if it is about to start booting but I just get a flashing cursor and no more.
I have tried another HDD with XP installed and this starts to boot but then stops and the PC reboots.
I have changed memory with no luck.
I do not have another cpu to try.
Any ideas? Could the cpu be dead?
Also the baord has a 20 pin and the extra 4 pin connector. Do they both NEED to be active or will the 20pin suffice if that is all the power supply has?
Thanks
Andrew
Thanks
Andrew
