Socket 775 Chipsets ?
12 Nov 2005
Can some1 briefly explain or point me in the right direction (another thread) that can explain to me which chipset i should go for in my new rig im planning ?
im looking at getting ;
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
and wish to use 2x 8800 GTS 640MB Gfx Cards in SLI
from *** i can see. i have the choice of intel 975X, 965P, Nforce 680, 650 ? .... im confused.
this will b the 2nd system ive built for myself and will also look in to overclocking. any advice would b great.
If you are looking at SLI then you want a mobo with 680i SLI, 680i LT SLI, 650i SLI or Asus do a mobo with a hybrid 650i SLI/570 SLI chipset (the P5N32-E SLI)
only the nVidia chipset currently supports SLI and I think the intel ones can support Crossfire natively/with hacked bios, I forgot which.
