A friend of mine has an EMachines E4064 with a socket 775 dual core processer. The problem the CPU idle's at 65 Degrees! So i've bought a Titan DC-775J925Z/R.
I came to fit it today but i noticed that the area with the pad on, is way to small for the size of the chip. Is this a problem,
I'll post the image so you can see what im on about, basically the cpu will overlap the holes on the bottom on the heatsink.
Will this work properly?
Any advice will be appreciated.
