Sofa rig
11 Sep 2009
I'm bored of my missus stealing my pc to play Fortnite :cry:
What gpu would be best for this to run on a 43 inch 4K tv? Or apu? It obviously doesn't have to be ran at 4K because well, I'm not made of money :cry:
Looks like you can get away with something pretty modest if you're prepared to upscale, what kind of budget do you have?
I've got a small ITX gaming pc for use with the TV and some sofa gaming. Running a GTX1660 Super and it performs really well at 1440p. My TV is 120hz with Gsync too and it'll play most games at medium/high with decent frame rates. Some older games are fine at 4k also, but playing from a distance it doesn't seem too noticeable being at 1440p.
Depends on your expectations really, I use a 6700XT for mine as I want to run native 4K at higher fps for mine, but if you are saying a used PS4 is actually an option then your expectations are probably not that high, so something like an RX580 or a GTX1660, 1650 Super. I would recommend the RX580 really though, the 8GB of VRAM is starting to show it's value I think (obviously this is used, if you wanted to buy new, I wouldn't really recommend anything lower end than an RX6600 as I don't think the value is really there).
