Hi i have tonight got freeview on my PC using a DVB USB dongle.
The Compro software will not pick up all the channels and is missing all the BBC and some others.
So i im using WMC which has picked up every single channel which is great but i cant resize the window to fit on half of one side of the screen, and can only window the screen in one corner. I would like some DVB software that will allow me to window half the screen when using WMC for live TV.
WMC will not let you resize the window for half of the screen for some reason, this is what happens when you try and drag to WMC
So im after some software other than WMC and the rubbish bundled Compro software?
What other DVB software can i use?
Thanks in advance.
Thanks in advance.
