Software for keeping tabs on Wages.
7 Jan 2009
Hey guys,
So im sure some of you use software to keep tabs of your working hours you do each week etc.
What would you recommend?
Im after something that auto adds your hours up if possible,I had a copy of Microsoft money somewhere but i cant find it anywhere..must have got thrown out. :p
Microsoft Excel is out of the question,too many things you have to learn to use it. :(
Could probably find an excel sheet on Google that has everything you need. I had a great one in my previous job, it counted flexi time as you built it up.
I'll make one for you later if you're still without one.
What kind of format do you work?
9-5 ish?
No weekends?
Expected hours per day?
Sorry for the late replies guys,
@welshdragon,Thanks for the suggestion...I should have mentioned i was really looking for freeware.
@bledd..Just having a look through Google now at a load of free time sheets,Found a couple of decent ones where you can input your start-end,pay rate and it calculates your hours within that shift and total for the week.
Here is what im after
BUT would like it so i can input my actual Start-finish times and not just how many hours i done,Just so if they mess my wages up at work (which happens a lot)..i can simply print it out with my start-finish times on and all totaled up! :)
Thanks for the offer of making one,Thats very kind of you :) ,But i will carry on looking first just in case i find one to save you the bother.
My working hours vary pal,I usually work Mon-Fri but do do the occasional Sat or sundays aswell as extra.
