Software for monitoring pc Watt usage?
14 Sep 2011
Walsall
Hi all ;)
Is their an deasn't programe to monitor my system so i can find out how much wattage it is taking to operate everything in it, ie: graphics /cpu/hhd/optical drive etc.
As i need one so i can find out how much spare watts i have for future upgrades.
Thanks in advance.
There isn't an accurate piece of software, you need a load meter on your psu kettle lead.
Got mine from a local computer bits and bobs shop for 10-15 quid. Power use at the wall is an eye opener, even when you take efficiency into account, some people would have you believe you need a massively over specced PSU
Software can show the wattage used by a component, but it can't show the input power is dependant on resistance caused by heat. Your psu will be 90+, but at the temperature it was tested at, which is probably different from your room :)
Wall metres are cheap though.
A watt meter is really handy to have. Also mine paid for itself in entertainment value by checking everything in the house out of curiosity. :o
