Software for various bits of hardware
7 May 2013
Hello :)
Finally got my new PC, and it's like a new world! Been a while since I set things up and was wondering what software (if any) people install for say Razer mouse, Steelseries keyboard, NV gfx card etc. Finding a lot of things nagging me and wondering what is necessary and what isnt?
Thanks!
For a Razer mouse, I'd install their software, configure it, then uninstall it (unless you need your DPI settings on screen). NV GPU, obviously you'll need the control panel applet (M$ store). I'd also recommend the Nvidia App beta if you have an HDR monitor (but probably wouldn't bother otherwise unless you need it for shadowplay). For GPU monitoring, I still use MSI Afterburner.
HW monitor (not the pro version) for all temp monitoring.
