software help please.....
6 Jan 2006
Newcastle
i need something that could help me in a couple of things ......
a prog or somthing that i can change file assocsiation with eg in explorer (since i have a partition i want all my files on the other partititon) so i want it to be able to click on my music and taken to F:|my music not C:\doc etc ....
and i would like a software that puts a password on the file ??? without having to zip them any help please
AJUK said:
Right click, properties, move.
huh ???
Foehammer2003 said:
dont know about the first points you raised, but Folder Lock is a good password folder program that i use to secure my o.O files :D
ty
i was also woundering on the right click menu can you remove items????
Oh ffs. I explained it as simply as possible.
You right click on your C:\My Music folder (or whatever you want) and then select properties, in the properties dilog box you will see a button marked 'Move'. Click it and then select where you want it to be located, in your case your F:\ drive, or wherever you need it.
