12 May 2012 at 19:06 #1 agnes agnes Soldato Joined 1 Dec 2006 Posts 16,926 Location Amsterdam, NL I used one once, showed blocks that were files, made it dead easy to see large files hidden. Cant remember the name of it. Reason, my new 128GB SSD has some how eaten up just over 20GB and I have no idea what used the space!
12 May 2012 at 19:23 #2 Chaos Chaos Soldato Joined 20 Oct 2002 Posts 5,603 I use Treesize to see large files. http://www.jam-software.com/freeware/ Think you can save space by disabling hibernation and turning off system restore.
12 May 2012 at 20:07 #3 agnes agnes Soldato OP Joined 1 Dec 2006 Posts 16,926 Location Amsterdam, NL Similar to that, but not quite. Thanks for those suggestions though mate! Totally slipped my mind haha. Saved me a good several gigs.
12 May 2012 at 20:26 #4 UnworthyBean UnworthyBean Associate Joined 15 Jun 2009 Posts 2,494 If I'm not mistaken, You're looking for WinDirStat?
12 May 2012 at 20:33 #5 agnes agnes Soldato OP Joined 1 Dec 2006 Posts 16,926 Location Amsterdam, NL UnworthyBean said: If I'm not mistaken, You're looking for WinDirStat? Click to expand... Thank you!!!
12 May 2012 at 20:43 #6 chaparral chaparral Caporegime Joined 27 Nov 2005 Posts 25,782 Location Guernsey UnworthyBean said: If I'm not mistaken, You're looking for WinDirStat? Click to expand... Thanks I Just found a sims 3 folder taken up 16GB in my C:/Public/downloads folder
12 May 2012 at 20:44 #7 Pho Pho Soldato Joined 18 Oct 2002 Posts 9,355 Location Derbyshire SpaceSniffer is also great .
