software to set fan speed based on GPU temp
24 Jan 2008
By Coffee cup...
Hi,
Is there one??
I went from phenom to i7.
on phenom I had a fan profile set in ai suite that worked brilianlty and thanks to amd running warmer then intel.
now i7 on idle is running much colder(around 20 degrees) and is not getting hot on full load...because of that GPU goes in temps of 60...while on athlon max was 56...
so am looking for a way to assign fan speed to the temp on gpu...any ideas ??
I know that 60 is nothing for 6950..but still 50degreed looks better ;)
any ideas?
MSI Afterburner, you can set a fan speed curve for different temps etc, also use for overclocking if you feel the need as well.
edit, just realised you want to control case fans, fan controller then I think.
I use the Scythe Kaze Server.
:D
I would recommended MSI Afterburner. I use it with my GTX580 and my friend with CF 6950 also uses it. Under the settings tab there is a fan profile bit with a graph. You can also set it to remember oc on startup.
