Okay guys and girls I hope this helps you out, seems Panasonic likes to hide the latest updates from it's customers.
Go to www.panasonic.co.uk
Select Support
Select Ask A Question
In the search field put pal-10 and click ask
The last of the 4 search results should be Software Update For 2010 Vierras so go to that one and there you have the download.
Alternatively this next link might get you there directly, it's ...
http://panasonicuk.epticahosting.com/selfpanasonicuk/template.do?id=49298
So this method is for SD/USB update.
Software update for PAL 2010 Viera TV’s
Some customers may experience the following phenomenons with their 2010 viera TV.
1. Iplayer Cutting out during playback.
2. EPG Guide not populating correctly.
3. A Freesat HD error message.
4. Incorrect channels being displayed when setting a timer program.
These problems have been identified and cured by way of a software update. Please download the software for your model type.
You will need to load the software onto an SD card to update the set Instructions on how to do this can be found here (http://panasonic.jp/support/global/cs/tv/download/fw/step3_uk.html)
The software update links are below (Please note the different software for VT20B models, Please ensure to select the correct screen size)
Plasma Models:-
Version 1.020 - C2B / C2L / S20B / U20B / X20L / X20B
Version 2.509 - V20L / VT20L
Version 2.705 - G20B / G20BA / S20B / S20BA / S21B / S21BA / V20B / V20BA / 50/65VT20B
Version 2.805 - 42/46VT20B / VT20BA
LCD Models
Version 1.020 - C20B / C20BA / C20L / C20LA / C2B / C2BA / D28BP / D28BW / LRG20B / S20L / U2B / U2L / X20L
Version 2.509 - D25L
Version 2.705 - D25B / D25BA / D26B / D26BA / D28BP / D28BS / D28BSA / D28BW / D28BWA / G20B / G20BA / S20B / S20BA / V20B / S21B
Select Support
Plasma Models:-
LCD Models
