- 4 Aug 2007
- Wilds of suffolk
The original inverter is irrelevant, as you need to leave that system well alone, the OP doesn't want to connect batteries directly to it anyway.
Adding an additional system should not cause the rent a roof system to clip, plain PV systems with a peak capacity within DNO export limits never used to have CT clamps. If that is the case and the DNO limits export, then the new system will have to clip (restrict) it's generation.
Lots to be considered, but should all be doable.
Comment on inverter was with regards to whether the system will still generate decent amounts in 25 years not in regards to adding or changing, not sure how you got that idea.
And yes my point was that its likely the export wont be controlled as its within allowance and hence right now adding another system will require change.
Cant simply add another system as that will potentially over export, and if export is limited based on the T&Cs its going to need to have export priority.
@Jimmyrn85 I assume from the T&Cs that you do not get the normal export payments at all? IE not FIT (obviously) nor normal export payments?
The T&Cs would seem to indicate that they receive the amounts in excess "any electricity which is not used will be exported to the grid for the sole benefit of the Tenant"
It would seem odd to put that if they are on deemed exports.
