- 19 Oct 2010
I got my tape measure out. With some slight movement we can get 7 x E and 7 X W + 1 x S. That gives me 15 so 5.5kw. I also have scope for 6 x S once an extension happens so the plan with for a 6 or maybe even 8kw SolarEdge inverter....pending successful DNO.
DNO options came back today..
"We have had a few options back from SSEN
Option 1 - Adopt a G100 Issue 2 Export Limitation Scheme – Install 14kW of generation as the total installed capacity but within this, set the Agreed Export Capacity to 3kW.
Option 2 - Network reinforcements/works required.
Option 3 - Cancel application
So, 1 it is"
So i'll be adding a 6kw SolarEdge inverter to my setup.
