So Iv been using a Dremel Versa Tip Butane Soldering Iron for a while. Now the Catalys has worn out and they are hard to get a hold of and they are expensive
Im looking at replacing it with a wired soldering iron with temp control and if the price is right a hot air gun.
I know for a decent bit of kit you are looking at a fair few £ but I only have a small budget of £50. Thanks
