- 10 Sep 2010
- Cornwall, England
Hi all,
I'm working on a project that will incorporate solid acrylic tubing (E22) with the use of bitspower crystal link fittings.
I want a small piece of tubing to go from the top graphics card waterblock to the CPU waterblock (with the use of some angled rotary fittings).
The problem is, how am I going to actually install the tubing if the graphics card and CPU waterblock are secured in place?
I thought about uninstalling the graphics cards, installing the GPU to CPU piece of tubing at the graphics card end and then trying to re-install the graphics cards whilst pushing the tubing into the CPU bitspower crystal link fitting... though that sounds really difficult
Any ideas chaps?
Any ideas chaps?
