Solid mid size case suggestions ?
29 Dec 2012
Im looking for some case suggestions, I don't mind getting something old (not the latest) or used
I have the phanteks Primo great case but it too big and I think I could do with a change.
I would like to get something smaller this time so maybe a mid size case.
I would like something with a solid build but also looks good and has useful features
it needs to have decent airflow
I Would like to keep the price low if possible, so dont want it to cost too much or able to pick up used.
I would like to be able to keep it for some time.
Some requirements
I use a air cooler the Noctua U12S, but its a good idea to keep bigger coolers in mind like the Noctua D15, so would need the CPU clearance
3-4 hdds ( backup storage) so it need to have room for them without having issues else were,
Other normal bits you would expect from a modern case
Would like some flexibility for the future (water cooling or air)
Some case I like the look of and wanted
Phanteks evolv / Evolve X
Lian Li O11 range
lian li lancool 2 mesh / 3
few other I like the look of
NZXT Flow
Corsair 4000D
Just need a little advice
The regular O11, not sure about CPU cooler clearance. I would go with the Air Mini.
Also the Phanteks P500 and P600 are very solid cases.
Previous Lancool (II and 215) can be found at B-Stock here at good price.
The Corsair, had the 5000D and the 7000D. Very good quality cases. The problem is, the price skyrocketed recently. With some luck you would find the 5000D for £80ish pounds new. The 4000D, according to owners, is a very versatile case.
Despite the O11 family look more like a showcase for custom loop, you can make it work great for air. Or the basic recipe: AIO at the top and side or bottom intake. Doing both would allow fans at much lower rpm.
Thanks, that was helpful
I've been using the noctua U12S, So I would need clearance of 158cm
Noctua D15 165mm or 168 mm ( little confused on this one )
For that reason the normal 011D is out for me.
