- 26 Dec 2019
- Denmark
I have a very simple question, which I have somehow successfully confused myself over. So I'm hoping one of you guys might know the answer to.
A couple of years ago I had a set of custom cables made specifically for my Corsair AX860 (non-i version) PSU. The cables were made to order by www.cablemod.com
I have recently sold the AX860 and bought a Seasonic Prime Ultra Platinum 850 instead. For now I'm just using the standard cables.
But I was wondering if anyone has an idea if the cables are interchangable, since the Corsair AX (non-i) is also made by Seasonic?
All cables fit and have identical connectors, including the 24-pin ATX cable, but I don't want to just go ahead and use the cables, since I don't know of any potential problems, and I wouldn't be able to afford byuing new hardware just because of incompatible cables causing damage.
I have contacted CableMod of course, but I was hoping someone might have an idea if it will work while I'm waiting for a response from the manufacturer.
Thanks a lot in advance for any replies
