(Solved) help needed with Time Spy Standard DX 12 Bench TR3960X & 4090
22 Oct 2006
I'm a bit rusty at benchmarking to say the least as I don't normally play games. but having upgraded to a 4090 mainly for productivity gains I thought I might have a play around with a few.
I benchmarked my system with time spy and I'm getting what appear to be low scores.
Am I missing some settings or are there some tweaks to do to get the best performance
ThreadRipper 3960X on PBO boosting to 4,400
128 GB of 3600 RAM
Zotac Trinity 4090 at stock
All temps are under control
One thing I noticed from GPU-Z is that the Resizable Bar is disabled. I have enabled it in BIOS, what else do I need to do
Last question is should I enable ECC in Nvidia Control Panel.
Many thanks in advance
Turns out that the benchmark does not like too many threads. I turned off SMT in the bios so I was only running with 24 actual threads. Once I had figured out that main part it was time for a few tweaks to see how good I could get the score.
Bumped the cores to 4,400
+1304 on Memory Mhz
+178 on GPU MHz
+2698 on Boost MHz
This Zotac Trinity is proving to be a decent bit of kit.
