Hi all, I've just build the following system with mostly new parts apart from a 2nd hand GPU.
Ryzen 5700x
16gb g.Skill Trident Z
Gigabyte RTX 2060 Super Gaming 3X OC 8GB Links: Gigabyte | TechPowerUp
1tb WD SN770 SSD
It was going well until I booted up Forza Horizon 5 and then the GPU fans ramped to 100% and stayed there, it sound like a mini jet turbine all the time when the game is running. Temps are a constant 89C with a hotspot temp of 107C. Even at 100% fan speed this does not change. I haven't even got the case closed up yet as I'm still tinkering with it. All other current games I've tried have the same end result, a hot card and me going deaf.
Ive tried following a video on Youtube from Optimum Tech and Tech Illiterate about undervolting but this has not made any difference that I can tell, I think I must be doing it wrong.
I also think I'm being a bit dim, I can't get the numbers in the spec linked above to tally with the figures I'm seeing in MSI Afterburner or in HWiNFO. Specifically the clock speeds, on the Gigabyte website it says this card should have a boost clock of 1710MHz and on the TPU site it says the base clock is 1470MHz.
In Afterburner curve editor after resetting everything the curve looks like this:
Am I getting totally mixed up? The clock speed it's showing at the top of the curve is 1995 MHz, how does that relate to the GPU clock speed?
After running the Time Spy benchmark in 3DMark HWiNFO reports this:
The trace from 3DMark looks like this and as you can see the as soon as it starts the temps shoot up and to me it looks like the pink line on the bottom chart shows that the card immediately thermal throttles? It goes from 1470MHz (Base) to 1200 MHZ and wobbles around from there until returning to 1470 MHz at the end of the test. I think throttling is also demonstrated between the demo and start of test one, as the temp briefly drops the clock speed increases for a short period before dropping again
Is this normal behaviour for the 2060 Super's? The seller I got the card from (another site) said he had cleaned the card and replaced the thermal paste and thermal pads, using Arctic pads and paste, but I'm wondering if he didn't quite get it right for it to immediately throttle.
Any help or suggestions greatly appreciated, thank you.
Ryzen 5700x
1tb WD SN770 SSD
