Solved i9 7900x psu issue
13 Jun 2015
Hello,
I am experiencing a major problem with my build, let me elaborate:
Today i decided to update the bios on my x299 aorus gaming 9 motherboard,
and after finishing installation when it was due to reboot it never turned on again.
There are no signs of power at all. I’ve tried to turn the computer
on via the power button on the motherboard without luck.
I had previusly updated the bios at least three times without issues. I was previously
on the F6 bios realeased in August and this happened while trying to install
F7A. The processor was at stock frequencies prior to the bios update.
What can i do? Everything had been running without issues until now. The
system was built in early July
The rest of the specs are:
Core i9 7900x (ouck)
Aorus Gaming 9 x299 (ouck)
Corsair vengeance lpx 16 GB 3200 MHz (ouck)
Cooler Master Liquid Pro 289 AIO CPU Cooler (ouck)
750 W Seasonic Prime 80 Plus Titanium (not purchased at ouck)
Gtx 1080 Ti.
Thanks in advance
HI,
Pull the power from the wall and the battery from the board, leave it for a bit and return to it and try again.
Any news epc1?
HI,
Hello,
I've just done the paper clip test for the psu and it seems to be the issue.
Tomorrow i will have a psu tester to confirm this.
I'll update the thread title or delete it as soon as i have confirmation it
is not the motherboard.
Thanks
Hello,
Just to update you:
The problem was the psu.
A replacement arrived today and everything is working fine.
Thanks for the help
