I have just built a new system:
MSI B450 tomahawk motherboard
AMD ryzen 5 2600 (without onboard graphics)
Nvidia gtx 1050 GPU.
PSU with 4 pin CPU power supply connector.
Suitable RAM
When I power up, the system appears completely dead, no MB LEDs, no fan activity anywhere. I have had the MB tested by the supplier and it is ok. The GPU has been working previously in another PC. The PSU is brand new. All is see is the power LED on the GPU come alive.
Two questions:
1. Is this CPU ok? The MB manual says that it needs ryzen 5 with Radeon Vega graphics. My CPU doesn't have that, is this a reason for the mb to appear dead? Do I need to use a CPU with the onboard graphics?
2. My PSU has a 4 pin pci plug for cpu power, but the mb has an 8 pin socket. Does this matter? Will the CPU work ok with just the 4 pin plug in the 8 pin socket?
if its not either of these, then what on earth is causing the whole thing to appear completely dead? No life or activity at all, apart from the GPU power LED lights up.
Many thanks
Suitable RAM
Two questions:
Many thanks
