Solving PNG transparency problem (IE) within CSS file
2 Aug 2005
I've found a couple of pages talking about the PNG transparency problem in IE, and I've actually managed to fix it, but when I fix it Firefox (and all other non IE browsers) stop working. Here's my CSS code:
Code:
#whole {
	width:730px;
	height:432px;
	padding:10px;
	filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src='images/overlay.png', sizingMethod='scale');
	background-image:url(images/overlay.png);
Even if I put the filter last, the fact that the background-image loads means the transparency doesn't work. If I remove the background-image bit it works in IE, but obviously not any other browser. Is there a way I can put some sort of javascript or something in the CSS so that only IE reads the filter and all other browsers read the background-image?
Thanks a lot,
Dan
only IE will parse links with an underscore in front...
so add an underscore to the filter and define a secnd background image with an underscore before it, defining no background image.
might work
That's great! All seems to be working, here's my new CSS FYI
Code:
#whole {
	width:730px;
	height:432px;
	padding:10px;
	_filter:progid:DXImageTransform.Microsoft.AlphaImageLoader(src='images/overlay.png', sizingMethod='scale');
    _background-image:none;
Thanks everyone :)
nav... said:
ok, that hack is copyright me 2006 :)
Be aware that the underscore hack has a different meaning in IE7 - that parser bug has been fixed. Properties with underscores will be added to the DOM as a custom CSS property, and ignored as their old interpreted property as in IE6. In this case, it's not an issue, because PNG alpha-transparency is in IE7, but for other cases it's not a good idea to rely on that particular hack for future compatability :).
you sure you're not laying an element over the actual links thus making them unclickable?
think about your z-indexs and stuff.
Yeah tried that, basically I've found that the above fix for IE actually makes the image on the very top (no matter what z-index you use). So...*sigh* yet another bug to get around. What I have done in the end is:
Code:
#left {
	float:left;
	width:345px;
	height:422px;
	padding:10px;
	overflow:auto;
	background-color:#94ddc6;
	filter:alpha(opacity=80);
	opacity:0.8;
And this actually sets a colour and gives it an opacity. It seems to work on IE and Firefox, AND all child elements inside the div that are hyperlinks work. Here's more info:
http://www.domedia.org/oveklykken/css-transparency.php
