Some 3800X All Core Overclock Gaming 4600Mhz 4625Mhz 4650Mhz
27 Apr 2014
AMD 3800X All Core Overclock 4625Mhz PC Gaming just for some fun.
Games 4K Ultra Settings
Added a couple Cinebench20 runs,for all the positive people.
3800X 4600Mhz Cinebench20 534
3800X 4650Mhz Cinebench20 540
Alien Isolation
Rage 2 35:21
Call of Juarez Gunslinger 41:51
26:30 Turned on Ryzen Master IF you want to see settings
31:35 HWinfo64 Turned on IF you want to see settings with voltage and temperatures
And for the people that will ask for BattleField 5 I did 2 videos at 4600Mhz with RTX On/Off ,had to use a little more CPU voltage for BF5 to be stable
Some 4650Mhz ALL core overclock light gaming loads.
At 4k would it make any difference to a 4.5ghz overclock? And if it's not stable what's the point?
It would make no difference. Maybe in the odd tittle but cannot think of any. I never saw my 4770K get cpu bound let alone my 3600.
I can get my 3600 stable for light usage at 4600MHz all cores also but the amount of volts it needs it is pointless. My sweet spot is 4400MHz all core where it is more efficient than stock settings and runs cooler. It is fully stable in all forms of usage.
If OP tried to run OCCT for an hour chances are he would end up with with errors or a reboot of pc.
Alien Isolation
Rage 2 35:21
Why not publish settings also?
The game frame time is 16.6ms which is vsync locked to 60fps. Very little cpu load. The settings are in one of the video's. He's running over 1.45 volts vcore for sure.
So the cpu has 1.475volts vcore IF1900 and ram 1900. The overclock is possible because of the light load.
I don't think it will be healthy running at that vcore for too long. Might lead to degradation. Considering it would make zero difference to fps at 4K while gaming, it is a bit pointless.
1.375 is the max I would consider as even at light loads there will be usage spikes.
