Some advice/Info please
Status
Not open for further replies.
19 Jun 2014
Please check this "MY-090-GS" (G.Skill 8 GB RAM)Does it come with instructions on how to clock to 3000mhz. Or does it have to be done manually on z87 and z97 boards. I'm asking this due to it only mentions there's a profile z97 boards. Thanks
What motherboard are you looking at using?
Majority of the times you will need to enable the XMP file in the BIOS or manually set the ram.
Status
