I've just purchased and received this cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-TQ
and have a few questions.
It will be used to cool an AMD Phenum II 955BE
Haven't installed yet - just been looking at the bits in the box.
Q1 - The base which contacts to the CPU is quite unusual - the four heat pipes are exposed and between them is silver coloured metal - so the base is a striped effect of copper and silver - is this good, bad, indifferent
Q2 - It comes with Tuniq TX-2. Is this good. I have my own MX-3, should I use that instead.
Q3 - The instructions for applying the TX-2 are quite unusual. Firstly it says to spread evenly over the whole heat spreader. Secondly it says "apply twice as much as usual" because of the unique base design. Does this sound right - my immediate thought it because of the striped metal base design, it may not be as smooth as other heatsinks so needs more gunk to fill in the gaps.
Q4 - I was surpsied to find that it comes with a fan speed controller - on a plate that mounts on the back of the PC. I assumed that speed of fans these days was controlled automatically by the BIOS and the MoBo. Is this speed controller a good or bad thing? The control knob won't be accessible so I guess I'll just set it on full and leave it there. I'd be also worried that if I set it low then the CPU might cook when the circumstances become right What do you think.
Q5 - At some point during storage or transit the fan has impacted one of the corners of the heatsink. As a result the fins are splayed apart at that corner. I guess it's a simple matter to bend them back and whilst I won't get them perfect I won't see it once it's in the case. What do you think - what would you do?
Cheers,
Nigel
Cheers,
Nigel
