Some advice on a pre built unit, pretty please
13 Mar 2016
My sons friend has been asking his dad for a gaming pc for a while now and their plan is to get him one for Christmas. Can you advise on whats the best pre built system based on the below:
Budget £1000 (not including monitor but to inc the OS)
Monitor will be 1440p @ 144hz
He mostly plays Fortnite at the moment but this will no doubt change over time.
What would be the best all round pre built system that can play Fortnite at 1440p with settings set to high/ultra and to achieve a decent frame rate?
Is it possible for £1k
Cheers guys.
Lee.
If you can install Windows yourself keys can be had for £10 SAVING £100 FOR better components.
Do you need wifi ?
Hi Micky,
We would need WIFI.
Im assuming to get windows we just download it and the purchase a key??
Thanks for your help mate
That's correct there are many guides online .
I have used slightly better components than standard config. Yo7 can also make changes to builds that not on the list by contacting them.
Would get them to change the cpu cooler from the brochen to this there about the same price.
https://www.overclockers.co.uk/jonsbo-cr-1000-gt-120mm-argb-cpu-cooler-black-hs-001-jb.html
CODE My basket at Overclockers UK:
  • 1 x OcUK Tech Labs AMD Ryzen Midi Tower Gaming PC Configurator = £1,011.90
    • Processor:AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - MPK
    • Motherboard:MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard
    • CPU Cooler:Alpenfohn Brocken ECO Advanced CPU Cooler - 120 mm
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Case Lighting:Unwanted
    • Operating System:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 10-15 working days
    • Memory:Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey
    • Speakers:Unwanted
    • Gaming Chair:Unwanted
    • Soundcard:Unwanted
    • Network Adapter:ASUS PCE-N15 300Mbps Wireless N PCI-E Adapter
    • Security Software:Unwanted
    • M.2 Solid State Drive **For Operating System If Selected**:WD Blue 3D NAND 1TB M.2 2280 Solid State Drive (WDS100T2B0B)
    • Solid State Drive 1:Unwanted
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:WD 1TB Blue 7200rpm 64MB Cache Internal Hard Drive (WD10EZEX)
    • Mechanical Hard Drive 2:Unwanted
    • Graphics:Gigabyte GeForce RTX 2060 OC Rev2 6144MB GDDR6 PCI-Express Graphics Card
    • Headset:Unwanted
    • Monitors:Unwanted
    • Power Supply:Corsair TX650M 650W 80 Plus Gold Semi Modular Power Supply (CP-9020132-UK)
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Gaming Desk:Unwanted
    • Case:Kolink Horizon Midi Tower RGB Gaming Case - Black Tempered Glass
Total: £1,026.00 (includes shipping: £14.10)
    • Speakers:Unwanted
    • Headset:Unwanted
    • Monitors:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
Thank you Micky, most appreciated mate.
What sort of settings and frame rate do you think that would achieve on Fortnite at 1440p??
Ask them to swap out the B450 Tomahawk for the B550M Mortar Wifi. The Wifi 6 on the Mortar is much better than the adapter in the build above. It costs £20 more but you are getting a better board overall.
I would also go with 3200MHz Ram.
Also the Ryzen 5000 cpu's are out tomorrow. If they are not buying until Christmas then maybe consider the R5 5600X. The R5 3600 is perfectly fine though if they want to stick close to the budget.
Total: £210.48 (includes shipping: £10.50)​
