some advice on cpu ?
  • Thread starter Thread starter Deleted member 61728
  • Start date Start date
Hi
I have had a q6600[b3] for about a year now and have been fighting with the temps idle 40c-53c idle,64c load atm i have it running at 3.1ghz around stock vcore and under water with a apogee block.
i don't understand even after multilpe remounts,multiple bleeds and after trying different layouts of the loop im getting almost no improvements in temp at idle or load.Is this just because its a hot b3 or does the block suck at cooling a quad ?
Is it worth going b3 to go ? if yes how much difference in temp ?
thanks
