Some advice on Heatsink options
29 Sep 2012
Brighton
Looking to upgrade CPU Heatsink so i can OC my (old) Phenom 2 x6 1095t.
Currently in a Zalman Z9 plus case and wonder is the H80's will fit? Or if anyone has any suggestions on what to use?
My issue is ventilation is limited where my PC sit's so the move is aiming to reduce case temps by pushing the hot CPU air out the back where it is moved away with an extractor fan.
Any help would be appreciated!
