Some advice on my build
8 Oct 2010
I have a overclockers bundle I got a while back here is the spec
Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz (4 CPUs), ~4.0GHz
Corsair 8GB (2X4GB) DDR3 1600Mhz Red Vengeance Memory Kit CL9 (9-9-9-24) 1.5V
Gigabyte GTX460 OC 1GB
Win 7 64
Is my CPU still up to par I know you can spend loads but I have been thinking about upgrading my GFX card is that a bottle neck in my system most games run really well on 1920x1080 on med/high. It just needs that extra kick.
Hmmm, I'd consider with the CPU you have (certainly the overclock) it would be the GFX that's holding things back. GX460 is an OK card but certainly not really up with the big boys these days.
Agree completely. A new GPU will definitely breath life back into your system.
760 or 770 depending on your budget. If its tight then I'm sure you will be happy with the 760
