Hi all,
I bought some components from OcUk at the beginning of last year, a C2D E6600, 2GB Corsair Dominator 8500C5D, Asus Striker Extreme 680i, a BFG 8800GTX (not OC - not available at the time) and an Enermax Galaxy 1000W PSU.
I've been running Vista Ultimate 32Bit quite happily for ages now without any thoughts of upgrading yet, but then I noticed the XFX 8800GTX XXX Edition that's appeared on this week only for £135 and I'm in a dilemma....
I can't afford to do any major upgrades at the moment like changing to a GTX 280, I originally thought that I'd wait for the 8800GTXs to come down in price and SLi mine to give me extra performance on Crysis etc, but as usual rather than the cards being reduced, they're phased out and are no longer available, or if they are, you end up paying more than the newer cards.
Is it worth me buying the XFX card while it's so cheap? I'm concerned that if I don't bother, I'll never get the chance to SLi my system because 8800GTX cards will no longer be available or should I be putting my money to a different card? (I can't see any new single card solution that's in the same £135 price range that would give me 2x 8800GTX SLi performance...)
One other thing, I was thinking of adding another 2Gb Corsair Dominator 8500C5D modules to give me 4GB. I know that Vista 32Bit will only see around 3-3.5GB, but does anyone know whether I'll get the Asus and 4GB problem that I've read about using this config. I've never had any problems with the 2GB I've got.
If anyone can offer some advice, I'd be really grateful.
Thanks.
Thanks.
(I nearly ordered two for 3-way SLi
, but the wife would've killed me!!
