Hello gents,
So, it is nearly upgrade time, should be a week and I will have the funds.
I see 2 options up ahead, which way to go?
I can either pop over to Intel and get myself a 4670K and an MSI Z87-G45 motherboard, or I can remain with AMD and go from my A10-5800K up to the 8350 and a motherboard of your choosing!
I will be getting a new PSU as well as my 450W is not powerful enough to team either with my R9 280X that I just purchased.
What way do you think I should go? I don't do any editing as such and mainly use it for gaming. I will be playing War Thunder (which runs fine anyway now so nothing to worry about there) but also looking at getting into Rome 2, if it gets fixed, ever! Skyrim with tons of mods too.
I know the i5 will perform better in single core performance, but does Rome utilise, or will it utilise, the cores on the 8350? I have had a look around on here and google, but google throws up so many posts from what seem uneducated fools, that I thought I best ask here.
I will be looking at a 650W PSU, probably the Superflower Golden Green 650W that is currently on at £73.99 but if there is a better choice please let me know, would like modular as my cable management is infantile at best.
To get the i5, PSU & Mobo, I am looking at £390.97, so would it be worth dropping to AMD and save some cash? What mobo would you recommend for the AMD?
