Some advice please
28 May 2007
Hello!
I got a pre-built system from Ocuk the other day which came with a 4850 graphics card. I upgraded to the 4870 but there was a mixup with the order so I have to send the 4850 back for a replacement but that's not the issue.
The motherboard has terrible placements for the SATA inputs - they are right in front of the PCI-E slot so a large graphics card can't sit in the slot properly without taking out the SATA cables :mad:
The 4850 card fits (just) due to the fan being in the middle of the card and it being 'open' on the end so the SATA cables sit pushed up against the card. I tried my brothers 260 gtx and it's physically impossible for it to fit as it's like a brick.
So I have a few questions really:
1) Do you know if the 4870 is the same size and layout as the 4850? I want to make sure I get a card that fits.
2) OcUK told me that the 4870 is a nice performance increase over the 4850 and good value for money (i've been out of the loop for a while), would I be better off looking at a different type of card or do you agree this is a good card to get? It's £45 to upgrade from the 4850 to the 4870
Cheers
5750 or 5770 maybe a better choice.
What motherboard is it?
Edit: The 5770 is just over 8 inches and the 5750 is just over 7 inches.
