Some advice please...
3 Apr 2012
Basically i am doing my first time build on a £400 budget and i was wondering if you guys can tell me if it is all compatible and if the case would fit as i am new to PC's.
http://www.overclockers.co.uk/showproduct.php?prodid=BU-083-OE
http://www.overclockers.co.uk/showproduct.php?prodid=CA-061-OP
http://www.overclockers.co.uk/showproduct.php?prodid=CA-057-OP
http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS
Just need it to play minecraft and later on i will add a GPU for BF3.
No need to start a new thread bud.
link
Avoid cheap and nasty psus like the one you selected.
Why mini itx?
Buy the individual components yourself rather than that bundle. For example why an i5 2500K and H67 motherboard?
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £173.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard REV 1 £84.98
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £71.99
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £43.98
1 x BitFenix Outlaw Gaming Case - Black £32.99
1 x Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £19.99
Total : £440.52 (includes shipping : £10.50).
Something like this. Case is personnel, iput in the Bitfenix just as an alternative.
As shadow-boxer has rightly said, don`t skimp on the PSU.
Does your monitor have a HDMI connecter?
link
Why mini itx?
Link doesn't work, looks like it's been removed.
Shadow - I assume you mean Buy an i5 2500k and H67 :confused:
Burnsb0y - Definitely DO NOT buy a £20 PSU.
Andi.
The Gigsbyte board only has a HDMI port for the onboard graphics. If your monitor does not spport HDMI, then you will have to get a board with vga. Can you let us know what connecters your monitor has or the make and model.
Do you have any sata harddrives and optical drive?
Ahhh, it is a VGA and also i dont have a hard drive though i do have an external optical drive i can use for it.
AMD Llano A8-3870K 3.00GHz (Socket FM1) APU Processor
Asus F1A75 AMD A75 Chipset (Socket FM1) DDR3 Motherboard
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM
Samsung SH-D163C/BEBE SATA 16x DVD-ROM (Black) - OEM
What about this then?
Only one problem, you will need to buy a GPU. The mobo does not have any monitor connection ports.
