Ok to cut a long story short
Got a Leon FR 150 TDi, (55 plate) which i have had 6 months and has 14k on it, bought with 9k on it. Now around 7 weeks ago i got it remapped with REVO which cost me £470, this took it from 150bhp and 230lbft of torque to 190bhp and 290lbft of torque.
Since getting it mapped i have noticed the clutch slip when you give it beans in 3rd and 4th, it probably slips in 2nd but its harder to notice because the turbo really does chuck you forwards and its hard to see the rev counter 'jump' if you will in any gear under 3rd.
I took this problem up with revo who say its my clutch NOT revo and that its on its way out, and that revo is simply showing up a future problem or weak clutch. I have no comeback with revo and they will not entertain a refund of any kind, beleive me i have tried.
Since the slipping i have turned off the remap (someting which you can do with revo) to see how the car pulls and feel under the standard ecu settings. The car is fine, no slip atall. To clarify this I have had in into seat for them to look at the clutch under warranty to see if it is defective, (of course with revo turned off, as the dealer can not see the remap) they can not find any problems with it atall, not a thing.
So this leaves me in a annoying situation, I either leave revo turned off permenantly basically flushing £470 down the bog and the car drives fine,
OR
Get it turned back on and drive it with clutch slip ( i can drive around it its not a massive deal) and then 1 year down the line when the clutch gets worse see if i can get it changed under warranty, as if it gets bad enough im sure it will slip when the map is turned off.
OR
Buy an uprated clutch which will set me back around £800, of which i just do not have, so that option is pretty much out of the window.
Any thoughts?
OR
OR
Any thoughts?
if they know that the car is stock and is going to be kept at stock then producing a map which causes problems on stock internals is not a good product and should be adjusted foc or a refund given
