Ok, finally got all my pc parts today, woop. Began the process of putting it together, first time to ever build a pc and to be honest, up to now it's proving more complex than I first imagined.
The heatsink/fan, an Arctic 7 Freezer Pro decided to play silly beggars,finally managing to click all 4 feet onto the motherboard i realised i had put it on backwards, much more fiddly than I had imagined.
Then came tha part of fitting all the wires, geesh, the only parts which are confusing me at the moment is the ATX power cable and the fans. So to my questions,
Mobo - Gigabyte DS3
PSU - OCZ Modstream 450w ATX2.2 Power Supply
Case - Lian-Li PC-60 Plus
1) My mobo manual states I should connect both the 24 pin ATX cable..and then the ATX_12v also into the mobo. Now, my PSU manual states on an ATX board I should slide out the 4 pin connector from the 24 pin connector and just use 20, then also attach the ATX_12v. So I'm assuming the 12v_ATX connector should definately be connected, but I'm not sure on the 20/24 ATX pin part.
2) Now my case comes with 4 fans, I'm assuming It'll literally take flight when I turn it on, but I don't see any connectors on my mobo or in the manual stating where these go, there is a SYS_FAN slot which I can connect 1 fan to (if take off the adapter end). Now I'm guessing i have to connect them all up using the cables I got with the PSU then connect them all to that single one somehow?
It'll be a miracle if the pc actually works when I (hopefully) finish it, assumingI haven't killed it with static or being too rough
So yes, any help would be so awesome, got a X1900xt here waiting to have a shot at Oblivion, just... sitting there.
Mobo - Gigabyte DS3
Used my other pc's one which seemed to work fine though.
