Some alterations
24 Aug 2003
Gillingham Kent
Have switched over to Sandybridge (i2500k). Decided to go two separate loops. 1 loop for the proc and the other loop for the TriSli 570's. Just awaiting some more parts so i can finish.
I had the quad rad sitting up, have switched it round so now it faces down. Cut the floor out and fitted a quad grill in there. Have ordered 2 G1/4 risers so I can get above the fans for tubing.
I made some brackets out of the alu from the floor to mount the front triple rad. Had to bend them so it sat back far enough to close the door.
At last finally goy her all back together
Run into a few minor problems. Not getting the right parts sent to me that I ordered. Things saying they are in stock but they were not. Had an EK D5 Xtop arrive and one of the 8 fixing holes was not threaded.
Parts for the 2 seperate loops:
D5 + Xtop
DDC Ultra + DDC pro pump top
Ek X2 res 250
Ek X2 res 150
Feser quad rad in the bottom
XSPC Tripple rad in the front
EK Supreme HF CPU Waterblock
Have a mixture of EK and Bitspower fittings
7/16 Primochill tubing
I5 2500k
Asrock Extreme 7 GEN3
Corsair Vengeance 8GB PC3-12800C8 1600MHz Dual Channel Kit (
3x GTX570
Crucial M4 256GB SSD
Gskill Falcon 128GB SSD
Must take those stickers off the front........Done
Its non reference but Ek have said that the 470 block will fit. Just havn't got round to ordering it yet.
Of course the card runs hotter than the W/C ones by (at the moment idle and just switched on)) 14 degrees. I think in games +20 degrees, so I will get the block and add it soon. Oh and its fairly loud
that board is the bees kness :D
does the yellowy colour not bother you when you look at the front of the case?
