Some audio help - External sound card or not
18 Mar 2012
Eastbourne
I've got an Asus U7 sitting here, and i've got an asus Strix mobo. I'm just wanting to know what would sound best, i've got some tannoy speakers paired with a cambridge audio amp, nothing special. but will I notice a difference using the U7?
Hard to say. Problem with asking is that there's no simple yes or no answer. Some people may notice a difference, some may not. Onboard audio is good enough now on better quality boards for the difference to be small enough for some not to notice.
As you've got both, I suppose it depends on whether the U7 is something you've owned for a while, or new and still in packaging. If it's used, then trying it and comparing for yourself is a lot easier than it would be if it were an internal sound card. If it's new in packaging and you don't know whether it's worth opening and trying it, then I'd probably just stick with the onboard audio.
Either way; unless you're using headphone as well, then you likely won't need what the features the U7 has to offer.
I use the speakers for general use, headphones when i'm gaming.
It's open I found it in my spares box, I totally forgot I owned it, i'll pop it in and see how it goes. Be rude not too.
