Actually, this originated in some old VB6 code that someone found an error in, and asked me to have a look at, but I've reproduced it in VBA for simplicity.
I thought the problem was due to defining some variables as 'Single' data type, but now I'm not so sure.
Edit: I should have added the results of that code:
XCofG: 331250.0000000
Weight: 135.1433000
331250 x 135.1433: 44766218.1250000
Moment: 44766230.0000000
Because the variables are defined as Single, Weight becomes 135.1433, XCofG is 331250 and moment should therefore be 135.1433 x 331250 = 44766218.125, but because it is also Single, and Single numbers can only have 7 significant figures, it should be rounded to 44766220, but it's rounded to 44766230, and I can't understand why?
It's almost like when it calculates Moment, it is not considering the Weight as a Single number, but using the full number to make the calculation, and then reduces Moment to 7 significant figures.
Code:
Sub BasicError()
Dim XCofG As Single
Dim Weight As Single
Dim Moment As Single
XCofG = 331250
Weight = (135.93 + 135.11 + 134.39) / 3
Moment = XCofG * Weight
Debug.Print "XCofG: " & Format(XCofG, "0.0000000")
Debug.Print "Weight: " & Format(Weight, "0.0000000")
Debug.Print "331250 x 135.1433: " & Format(331250 * 135.1433, "0.0000000")
Debug.Print "Moment: " & Format(Moment, "0.0000000")
End Sub
Weight: 135.1433000
