Got a few questions on cooling fans. First up, my current setup consists of 2x yate loon d12sl-12 1300 rpm fans on my case, 1 intake, 1 exhaust. On my TRUE120 i currently use 2x arctic cooling 12025 400-1500 rpm pwm fans, both powered via the 4 pin cpu header. Ive ordered a scythe kama bay to add an extra yate loon for more air intake, and a pair of sharkoon silent eagle 2000's for the cooler. Will i be able to control 1 of the sharkoon fans via a 3 pin mobo header and the other from the 4 pin cpu header.. The 2 intake fans i intend to run from a single 3 pin header (only 4 of the 5 fan headers support bios fan control, incl cpu on my board) Looking to push my oc above 3.6ghz and my current cooling may not be sufficient. tia
