I am thinking of overclocking my Phenom ii 4 955 black edition just a little bit from 3.2 to about 3.6 gz.
I would like to replace my stock heatsink and fan,but I have a small budget I would like to get a replacement for about £12-£15, I have found some, I looked at the Cooler Master Blizzard T2 ,I then noticed that once installed it would blow right on top of my graphics card,if the fan was on the opposite side it would be almost into my PSU.
I felt then I needed a replacement that fitted the same way as my stock AMD heatsink and fan, the ones I have seen dont look any better than the one I have. Indeed there seems to be very few that blow air out the side which I have now.Should I just replace the thermal paste and forget a new heatsink/fan ?
Many thanks
Many thanks
