If you add these two lines to the [TERRAIN] section of your FSX.CFG, you can define the max number of objects in a terrain cell for trees and buildings independently. The slider will scale down from the numbers you set as the slider is moved to the left. The max tree value in FSX as released is coded to default to 4500 and the building default is 3000 (as shown below) and the absolute max FSX will recognize at all is 6000. Of course if you raise the values beyond the defaults, you will obviously be increasing density and lowering fps (so don't complain if you do this...). The point in sharing this information is that with these settings you can specify what the values are yourself. Be sure not to set either number to 0 as that will cause problems, but setting it to a very lower number will give you nearly 0 objects.
TERRAIN_MAX_AUTOGEN_TREES_PER_CELL=4500
TERRAIN_MAX_AUTOGEN_BUILDINGS_PER_CELL=3000
