Permabanned
- 26 Nov 2006
- guildford, surrey
Not sure if this should go in overclocking forum or motherboard, but i expect more people would know here.
Firstly im currently at 3ghz on stock volts, and i want to hit 3.2, ive had it there before but 1, it was quite unstable due to stock volts, and 2, my ac7 was constantly at 2500rpm so it was like a helicopter taking off, and whilst it kept it cool, it was way too loud.
Is there anyway to set the fan speed to a constant 1000-1500? So it does a good job cooling but isnt too loud? Ive been told theres a problem with gigabyte boards where you cant adjust fan speed?
And secondly, I dont know anything about volts and stuff, how do i just nudge it up a bit? Just a little bit so its more stable at 3.2?
Cheers.
Cheers.
