Well I have had a terrible purchasing experience in fact I would say the worst I have ever had in buying computer components.
I purchased an Asus Maximus VII Formula Motherboard from a well known competitor (in Bolton) of OCUK (yes your right that was my first mistake!). I got the board and installed everything and kept getting a message that a new CPU had been installed push F1 for settings, no matter what I did the message always came back. After a number of attempts at remedies and a very careful inspection of the CPU and the socket under my 4X day light magnifying lamp I concluded the board was defective and contacted the retailer for an RMA. This was 2 days after receipt of the board. It took 4 more days for a response and that was to ask me to produce photos of the board and socket. I baulked at this and asked again for an RMA number. I got one and returned the item immediately. Today my RMA has been rejected on the basis that there is socket damage. I have yet to see what damage but I will be asking for a photo. Having been installing CPU's for around the last 20 years and having never damaged a socket or processor in all that time its of course likely that somehow I did this time.
As it is I had already read around a number of forums and concluded that this outcome was extremely likely as it seems to be the go to policy of the retailer in question when dealing with RMA requests on motherboards. I had actually said to my Mum days ago that they would reject it on the basis of damage and lo and behold that's what has happened. As it is I had in fact already purchased an identical replacement board from OCUK on the basis that I did not expect to get a successful RMA from the other retailer and needed a replacement immediately to get my system back up and running. This board by the way worked perfectly first time and somehow I managed to install it without doing any damage to the socket!
Anyway this is not intended to be a whinge but rather to offer advice to others from my expensive experience. Firstly I would say on receipt of a motherboard it should be very closely inspected immediately it leaves the box and photographs taken of its condition. Secondly if a fault becomes evident then prior to any RMA it should again be inspected and photographs taken of its physical condition. I really missed a trick here as I didn't take any photos of it prior to its return so I can't prove one way or another if it was damaged when it left me. I would say this is absolutely essential in any RMA of a motherboard, be prepared to prove by way of photos the condition of the board on its arrival and prior to any return.
Secondly in dealing with this particular retailer it is clear that in the case of motherboards regardless of any defect it is highly likely that damage will be found by their testers and any return rejected. Thus the installation insurance (which I would view as nonsense most of the time) is actually an essential purchase in the case of motherboards. It is probably the only way you will recover any money in the event your board has a defect. The bottom line is that in dealing with this particular retailer if your motherboard has any kind of defect then it is very unlikely that you will be able to successfully RMA it and get a replacement or refund. I would be interested to hear from anyone whose experience differs and has been able to successfully RMA a motherboard to this particular retailer.
I had a quick look through Quicken tonight and by my reckoning over the last couple of years I have spent around £4100 with this particular retailer. Its not a huge amount but its actually a lot for me as I am disabled and on a pretty low income. In fact my computer makes up a large proportion of my spending because it's so central to my day to day existence. I very rarely leave my house and the life I lead through the computer is a godsend.
I hope that others can learn from my bad experience and have a better outcome than me.
