Some hardline advice needed
17 Mar 2009
Scotland
Hey guys,
I've been reading about a number of issues with monsoon hardline collars cracking and its kinda put me off wanting to use it on my Midas upgrade.
So I was wondering about the use of copper instead. I'd like to hear from anyone who has used it or can point me in the direction of a guide.
I want to know about any issues with using it, corrosion dependant upon blocks used etc. What fittings are best, can it be easily painted as I wouldn't want to have a copper finish.
Its that or I switch over to the likes of bitpower for hardline. So I'd appreciate any thoughts on the subject.
I did want to move away from soft tubing, but its a safe/safer option. Considering how much money I've put into my Midas upgrade plan I want to minimise risk of leakage and the resulting damage.
Thanks
