Just started to play with OC, have basically no previous experience. I have i5 3470k CPU and Asus P8Z77-V LX Intel Z77 mobo.
I changed multiplier to 42, now it runs at max 4200 MHz, I updated the voltage to -0.005, because if I leave it on Auto, voltage goes up to 1.35 when running full load, and 0.000 changes automatically to Auto. With -0.005 I reach 1.256 core voltage once windows just loaded and still starting services. Testing with prime95 for max heat it reaches 1.2 with temperatures up to 71C on full load. I'm quite happy with everything just wondering if voltage is good, not too high?
Also there seems to be weird issue with not showing bios screen on start, going straight to windows, not always, but when it happens I have no mouse control until it loads into windows 8 cover and then I have to click some button on keyboard to remove screen cover and only then my mouse appears, while usually if bios screen shows at start, my mouse is available at the OS choose window. I have Ubuntu installed as well. I have also tried to keep clicking delete button constantly while starting pc, and that doesn't help as well.
UPDATE
Also there seem to be different number of voltage in CPU-Z and Core Temp programs, while CPU-Z shows up to 1.256, Core Temp VID field shows up to 1.31, which one I should believe?
UPDATE
